Title:Expanded PTFE joint sealant
Expanded PTFE (EPTFE) Joint sealant is a soft conformable product that is clean and compatible with 99% of chemicals (except molten alkali metals and elemental fluorine). EPTFE is much softer and more flexible than regular PTFE
Expanded PTFE joint sealant Application:
Expanded PTFE joint sealant is specially suited for sealing flanges connection, pipe systems, hydraulic and pneumatic system, etc.
Prime Features
1.Saves money and time
2.There is no scrap or waste, it costs less than other gasket material
3.Installation time is kept to a minimum since there are no templates, precut or special fitting requirements.
Expanded PTFE joint sealant specifications
MediaAcids, alkalis, solvents, gases, etc.
Temperature-240℃to260℃
Pressure100bar
PH valve0-14
DensityGrade A/B 0.70/0.80g/cm³
More specification please leave your message or contact us .low price PTFE Joint Sealant
website:http://www.rilsonsealing.com/ptfe-products/ptfe-joint-sealant/
Prime Features
Pressure100bar
PH valve0-14
