Industrial Water Ionizer suppliers
dflong123
Новый пользователь
22.06.2020
10
1
Antioxidant Industrial Water Ionizer For Food Plants Or Farm 5.0 - 10.0PH
Commercial Acidity Water Ionizer Model No. EHM-2000
EHM's Newest High technology industrial & commercial water ionizer, with 1000L/hour Better Performance!
Specifications
Continuous Working Commercial water ionizer 2000/h alkaline & acidic water outputting. The PH value of the Alkalescent Water is between 5.0 and 10.0, it is more than 2000L/h.
Use life of electrolyzed slot is more than 2500h. The dimension of the machine is L140*W75*H200cm.
Working Condition
Source Water: The source water can meet the standard of our country and the rigidity is less than 100mg/L and the water pressure is between 0.1 and 0.25Mpar. The rigidity of municipal water is less than 100m according with national standards and the water pressure is more than 0.3Mpar. Environment temperature can be from 5 to 40掳C and the humidity is less than 80%.
The net weight is 350KG including the following fittings: 2 switches, 1 fuse, instructions for ORP, ph, conductivity, several plastic parts. Acidic electrolyzed oxidizing water, low PH value (2.3 or less) and high ORP (+1100 mv or above), beyond the scope of various pathogenic micro-organisms to survive and make cell membrane potential change, leading to cell membrane permeability-increasing and the destruction of cell metabolism enzymes, microbes quickly die. Meanwhile, the acidic electrolyzed oxidizing water and contains 50-80mg / L of chlorine to more effectively kill pathogenic microorganisms.
Application:
A. For restaurants, food plants use: improve the food taste, and keep the nutritions in the vagetables and meats.
B. For directly drinking: Keep body pH balance and avoid the sub-health and diseases. With the smaller molecule, the water is easily absorbed by the body.
C. For the farm use:
(1) Can keep the cattles health, keep their furs shining, and improve the milk production.
(2) Can control and offer prevention of fruits, vegetables and other plants from a variety of diseases, alternative chemical pesticides;
(3) Could effectively degrade the surface of plant pesticide residues;
(4) Could effectively kill the seeds carried by micro-organisms and fungi;
(5) Can be suitably modified alkaline soil.
Water Storage conditions:
(1) Water storage containers to be sealed;
(2) To avoid direct exposure to light;
(3) The storage ambient temperature is not greater than 40 Celsius;
Under these conditions, the alkaline & acidic electrolyzed oxidizing water could be stored for at least 90 days.
Safety Emissions: acidic electrolyzed oxidizing water in irrigation or placed after a certain time, be able to restore its own ordinary water, and plants were polluting the environment and residual.
Place of Origin:China
Brand Name:EHM
Model Number:EHM-2000
Certification:CE
Voltage:110V/220V/380V,50Hz
Power:3000W
Working Mode:Continuous
Weight:350 KG
Water Pressure:0.1-0.25MPa
Water Flow:2000L/h
electrolyzed slot life:鈮?500h
Ambient Temperature:5鈩儈40鈩?/p>
Humidity:鈮?0%
Atmosphere Pressure:86kPa~106kPa
PH:5.0~10.0
Source waterMunicipal water according with national standards
Rigidity<100mg/L, water pressure 鈮?.3Mpar
Fittings2 switches +1 fuse+ instructions for orp+ph+conductivity+several plastic parts+ a lock which is for the back door (to avoid the shipping damage, we will don鈥檛 install it)Industrial Water Ionizer suppliers
website:http://www.commercialwaterionizer.com/water-ionizer/industrial-water-ionizer/
