D
Deck combination azimuth thruster is a kind of marine power propulsion which combined azimuth thruster and diesel engine. They have the advantages of compact structure, high mobility, convenient install and others. The whole set can be installed directly on the deck base. The set is hooded in the container. The vertical height is adjusted by mechanic equipments or hydraulic equipments. Therefore, ships can adapt the deeper to suit for the water depth and give full efficiency propulsive force. The ships can better satisify the full load and no load propellers immersion depth need. The combination design with contra-rotating propellers can further shorten the diameter of propellers, save ballast water treatment cost and ballast water adjustment time.
ModelPower RatingSpeed RatingDia of propellerClutch completeMatching
(HP)(r/min)(mm)Diesel Engine
RFDRP1201202200860HCL100F6BT5.9-M120
RFDRP30030018001080HCL250FNT855-M300/WD615.64C
RFDRP60060018001300HCL320FKTA19-M600/8 M26.2
RFDRP90090018001680HCL600FKTA38-M900/12 M26.2
RFDRP1200120018001750HCL800FKTA38-M1200/12 M26.2
RFDRP1600160018001850HCL800FKTA50-M2
RFDRP2000200018002050HCL1000FKTA50-M2
Mentioned data for indication purposes only.
Deck Mounted Thrusters manufacturers
website:http://www.wxrefine.com/deck-mounted-thrusters/
