G
Efficient vertical integrated double-stage combination air flotation equipment/cavitation air flotator/pressure jet air flotation equipment
Cavitation air flotation machine: This machine is mainly used for purification of municipal sewage and industrial sewage from papermaking, chemical industry, printing and dyeing and oil refining. The applicable materials include: high oil, high suspended solids and high COD sewage. How to treat sewage? What equipment can be used in the sewage treatment process to ensure sewage conforming to national standards for discharge or reuse and make the process economical in operation? In this regard, our company has introduced foreign advanced technologies to produce CAF series cavitation air flotation equipments for water treatment, which are mainly used for purification of municipal sewage and industrial sewage from papermaking, chemical industry, printing and dyeing and oil refining.
1. Uses
In the process of water supply and drainage treatment, the separation technology of solid and liquid as well as equipment is one of the key projects. Air flotation is one of the most effective methods for the removal of the fine particles suspended which are close to the water in the proportion.
2. The representation method of model number
3. Features
1. Small land occupation, little power consumption, easy to operate and simple to manage;
2. High dissolved air efficiency, stable treatment effect, and the integration of control of machine, electricity and instrument;
4. Structure and work process
The WF type combination air flotation device is made up of air flotation tank body, dissolved air system, dissolved air return line, dissolved air water release device, foam scraping device (including combined type, driving type and chain plate type used respectively according to the needs of users) and electric control cabinet and other components.
The major role of air flotation (can reduce COD, BOD and chroma and so on at the same time) is the separation of solid and liquid. Add the flocculant PAC or PAM in raw water, and raw water enters the contact zone of the combination air flotation after the effective flocculation reaction (time, dose and flocculation effect must be experimentally determined). In the contact zone, the micro bubbles of dissolved air water and the floc in raw water mutually bond and enter together into the separation zone, under the action of the buoyancy of the bubbles, the flocs and bubbles rise together to the liquid level, forming scum. Scum is scraped by scraping foam device to the sludge zone. The fresh water in lower layer flows automatically through the collector pipe to clear water pool. Part of fresh water flows back which is used for dissolved air system, and the other part is discharged.
Through the jet flow inhale device, under certain work pressure, return water makes air dissolved into the water to the maximum extent, becoming the dissolved air water, and in air flotation contact zone, through the rapid decompression release of the release device, the dissolved air water forms micro bubbles with the diameter of 30um-50um. The micro bubbles can adhere to each other with the flocs in raw water.
Outline drawing is shown in Figure 1 and Figure 2, the technical parameters are shown in Table 1, and the overall dimensions are shown in Table 2.
Technical parameters
Model numberDealing water amount (m3 / h)Dissolved air water amount (m3 / h)Size of separation area (m2)Main motor (KW)The aerated motor (KW)The foam scraping machine (KW)Equipment weight (KG)Operating Weight (KG)
WF-21~20.4~0.80.720.550.550.188002000
WF-32~30.5~110.750.750.3711003600
WF-53~51~21.514004400
WF-105~102~331.519009400
WF-1510~153~54.52.20.55240012400
WF-2015~205~75.4300015000
WF-3020~306~1283.01.5370021000
WF-4030~408~13115.5430026500
WF-5040~5015~2013.50.75495033000
WF-6050~6020~25167.555003900
WF-7060~7020~2519.5600045000
WF-8070~8025~2821.5112.2670052000
WF-9080-9025~3523720059500
WF-10090~10030~352815780068000
WF-120100~12035~4533860077000
The installed size of combination air flotation equipment (mm)(WF-2----WF-30)
Model numberWF-2WF-3WF-5WF-10WF-15WF-20WF-30
L180022002400350040005000
L1150015001700250030004000
L2200029003100420047005700
L350010002000
B65080010001200150018002000
B1300400500
B21100190021002300260029003100
H135017002000
H1150020002300
H290012001500
DN25050100125
H390250300
DN35080100125150
H48508501054
DN44080100
H5515600850
DN5252550
H680140150
DN6325080
The installed size of combination air flotation equipment (mm) (WF40---WF120)
Model numberWF-40WF-50WF-60WF-70WF-80WF-90WF-100WF-120
L600070008000900010000
L1600070008000900010000
L27200820092001020011200
L3200025003000
B22002700280030003200340036003800
B1500600
B230003450355037503950415043504550
H21002200
H124002500
H2110010501200
DN2150200250
H3300350350
DN3200250300300
H411001350
DN4150200
H5150
DN680
Should you have any preference for the efficient vertical integrated double-stage combination air flotation equipment/cavitation air flotator/pressure jet air flotation equipment, welcome to buy or wholesale the product made in China from our factory. We are known as one of the professional manufacturers and suppliers in this field.China Double stage air floatation manufacturers
website:http://www.shallowairfloatation.com/air-floatation/combination-air-floatation/
1. Uses
3. Features
L350010002000
B1300400500
H135017002000
H1150020002300
H290012001500
DN25050100125
H390250300
DN35080100125150
H48508501054
DN44080100
H5515600850
DN5252550
H680140150
DN6325080
L3200025003000
B1500600
H21002200
H124002500
H2110010501200
DN2150200250
H3300350350
DN3200250300300
H411001350
DN4150200
H5150
DN680
