G
Product Description
ADH100-E 8-36VDC 100A Load 12-900VDC Energy Saving Type 1NO Contact For HV Power Supply System AOKAI High Voltage DC Contactor
ADH series DC high voltage contactors have standard type(Q type) and energy-saving type (E type). ADH100-E contactor belongs to the energy-saving type high voltage DC contactor. Coil voltage is 8-36V DC, current is 100A, load voltage is 12-900V DC, 1000V can be custom-made, action voltage is 7-8V DC, release voltage is 5-6V DC, minimum starting current is 1.5A, IP grade is IP 67.
FAQ:
Q1: Can I have a sample for testing?
A:Yes, sample is available, but you should afford the cost.
Q2: Can I add my logo on the products?
A:Yes, OEM and ODM are available for us.
Q3: How can I get the after-service?
A: The damage caused by the quality problems will be borne by our company, we will provide the replacement or repair according to the particular situations.
Q4: Do you have inspection procedures for products?
A: Our products are 100% self-inspection and testing before packing.
Q5: Can I have a visit to your factory before the order?
A: Sure, welcome to visit our factory.
Here is our factory address: NO.89 Yanhe East Road, Liushi Town, Yueqing City, Zhejiang, 325604 China.
Our factory is near the Wenzhou airport, and we can pick you up in the airport, hotel booking service is available.
Q6: How about the delivery time of the order?
A: It is according to the order quantity, we will note it in the quotation.
Q7: How about the payment terms?
A: It is also according to the order quantity. Quality customers could enjoy the better payment terms.
Brand: AK/AOKAI
Name: High Voltage DC Contactor
Model: ADH100-E
Rated Coil Voltage: DC8-36V
Rated Load Voltage: DC12-900V
Power Consumption: 2-2.3W
Leading Out: M5 Internal Thread
Rated Current: 100A
Dimension: 54.7*49.2*62 (mm)
Weight: About 190g
SPECIFICATION
Contact Type1P (1NO Contact)
Contact Resistance≤0.4 mΩ (100A)
Contact Related Load (Resistance)100A 500VDC
Max. Switching Current1000A 320VDC ( over 1 times)
Rated Voltage(12-900)VDC
Max. Switching Power320kW
Withstand VoltageBetween Contact and Coil4000VAC
Between Contacts4000VAC
Air Gap>8mm
Creepage Distance>8mm
Mechanical Life (times)1×106 times
Rated Electric Life (times)10,000 times
Coil Outlet MethodsOutlet wire
Load Outlet MethodsM5 Internal Thread Screw
WeightEnergy-Saving (E)About 190g
PackingPlastic Sealed
External DimensionEnergy-Saving (E)54.7×49.2×62mm
Vibration10Hz~500Hz 10G
Humidity5%~95%RH
Temperature Range-40℃~85℃
USAGE ENVIRONMENT
IP GradeIP67
Operate Temperature-40~+85℃
Operate Humidity5~95%RH
LOAD SWITCHING LIFE CURVE
INSTALLATION DIAGRAM
SCHEMATIC DIAGRAM
Aokai Electric is your best source for the high quality 120v 200v battery car motor high power dc contactor relay with CE certification. We have been one of the largest such manufacturers and suppliers in China since our establishment in 2008. Welcome to contact our factory for the products.Battery Car Power Relay manufacturers China
website:http://www.ak-contactor.com/high-voltage-contactor/battery-car-dc-relay/
FAQ:
Brand: AK/AOKAI
Model: ADH100-E
Rated Current: 100A
Weight: About 190g
SPECIFICATION
Air Gap>8mm
Humidity5%~95%RH
USAGE ENVIRONMENT
IP GradeIP67
SCHEMATIC DIAGRAM
